2" pipe "T" fitting template Tools
OK! After many attempts I finally got it. For ANY size pipe! You first get the circumference: 2πR=Circumference. That will be the overall length of the template. You divide the length by 4. That gives you the wave pattern. To find the peak to peak of the wave pattern you multiply the radius of the pipe by .707 and that will give you the peak to peak pattern for your pipe. I hope this helps. Thank you
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Robert Pattillo for the original creation.
6 years ago
68
  • round pipe T template v4.dxf
