WIFI Router Bracket Office
9"x6.5" bracket to mount router or whatever you would like to.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Eric Wiersema for the original creation.
6 years ago
201
  • WIFI Router Bracket2.dxf
  • Daniel (Langmuir Systems) - 6 years ago
    Very cool, the integrated bend lines are a smart idea.
  • 4WheelinManiac - 6 years ago
    definitely going to use this!
  • Tom Johnson - 6 years ago
    I will download the file when I can to try to understand how you put those bend line cuts in there. I haven't been successful cutting slots so that I can bend on. Not sure about the setting.
    Robert Phillips - 5 years ago
    for slots, try to put your lead in point at the meddle of the radius and set the angle to 90 degrees.
  • Beginner - 5 years ago
    Hi, how are you bending the plate or which tool to use? thanks
  • Eric Wiersema (OP) - 5 years ago
    I just put it in a 3 foot brake and bent it, you could try a bench vise also
