1" test square 1/4" holes 1" diag Tools
This is a small test piece to save material while setting trying to dial in the setup. 1" square .25 radius on holes and 2 corners with 1" diagonal straight line.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Frank L for the original creation.
318
test cut test square coupon test coupon
  • test square.dxf
  • Frank L (OP) - 2 years ago
    Just as a reminder you may want to separately cut the holes first at a reduced speed of around 60% the normal cut speed. THC will not be used on these due to their short cut length. So 2 cut profiles, small holes first :)
