20x20 Fire Pit Home & Garden
Very Simple Fire Pit. Steel is 12g You will need: 4 sides 1 base Plate 1 leg (file makes 4 legs) Assembly: Each side should be angled somewhere around 50degs. I tacked on the inside until I had all 4 sides on. Then welded up the entire outside seem. You can either chose to grind down the welds like I did or just leave them. The legs I desgined so they can be bent. I found this just made getting a square base a lot eaiser. I finished mine off with High heat paint from lowes (the 2000f stuff) im sure after awhile I will need to re paint Depending on where you get your metal it costs around $30ish dollars to make not including paint.
You may remix, tweak, and build upon this work non-commercially, as long as you credit Tom and license your creations under the identical terms.
2032
Fire Pit welding fire
  • Base Plate.dxf
  • Legs.dxf
  • Sides.dxf
  • Tom (OP) - 4 years ago
    Cal Spigler - 4 years ago
    Hey Tom, great video. What brake do you use in the video?
  • Chris Allen - 4 years ago
    Thanks Tom.
  • Thomas johnson - 4 years ago
    Thanks cant wait to give it a go
    dont be THAT guy that takes the file and trys to sell the plans!
  • DogCreekCustoms - 4 years ago
    Personally I would of slotted between the panel and the legs a nice long slot with a quarer tab on both ends and in the middle for even the guys like me that don't have a metal break can still bend the panel & legs then you can weld the seam to stiffen it back up or even slide a ash plate between if desired. Nice design though. :)
  • Chris - 4 years ago
    Thank you sir!
  • Phil - 3 years ago
    Going to give this a try! Thanks Tom
  • scott - 3 years ago
    What's the total sq footage of material needed?
  • Jordan Wall - 1 year ago
    Is 20x20 the finished length x width measurement?
