Mach3
I use these for cage perches, you can use them as body mounts etc. In the pic you'll see I put in cut reliefs, that is an option in the .dxf file if you want to add them to the piece. that will make this item easier to bend in a vice if you don't have a bender, you would just weld the reliefs once you bend it. If you make a 3/16" x 1.125" relief, once its bent the opening is less then 1/8". This is designed for 1/8" steel.
108
roll cage perch car bendable
