Very cool! What thickness plate did you use? Did you throw this over like a larger "cowboy" grill?
Jordan Beukema (OP) - 3 years ago
I used 1/4" mild steel. yes just open one half at a time.
Thanks
BJJ Custom Cuts & Engineering - 6 months ago
I just tried to cut this, Fusion programmed with all the slots together and it started to warp like crazy. Did you program to jump across the sheet to keep heat down?
