3/8” Hole Flat Weld Tab 1” Standoff Tabs & Brackets
6 years ago
563
  • 0.375in Hole Flat Weld Tab 1.0in Standoff.dxf
  • Corey - 5 years ago
    again thank you for the time savings
  • Keiwat - 3 years ago
    thank you, will need to cut a few of these
  • Ronald Herring - 1 year ago
    Thanks
