3D Plane Art
Found this on freepatternsarea.com which is free site and modified to cut using 16ga steel. I tack welded it and will be a nice addition to my yard art. Please don't sell dxf on any site as your own. I see many people passing off designs as their own. This isn't my design and I share for others to enjoy a fun project. I appreciate others doing the same.
264
  • Plane - 16ga steel.dxf
  • John Sabarese - 2 years ago
    So cutting that size what is the wing span?
    Don P. (OP) - 2 years ago
    17" is wingspan but you can scale as you want. You just might need to adjust the size of the areas that fit together.
  • mitch - 2 years ago
    fyi the dxf is missing wing alignment slots and structure in the frame pieces. needs work prior to cutting,
  • Don P. (OP) - 2 years ago
    Just FYI...no wing alignment slots are needed in top wing and not sure what you mean by structure in frame pieces. It's a little puzzle but use my pictures to help you build it.
