4-sided Dice Art
D&D novelty item. 4 sided die.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Dustin E Voelzke for the original creation.
87
dungeons and dragons dice game
  • James Mersereau - 1 year ago
    Thanks for sharing. It looks like a fun project. If you want other to be able to cut this you need to share the NC, TAP, DXF or SVG file. If you share both a CUT READY file (NC or TAP) as well as at least one modifiable file (DXF or SVG) you will give others the most flexibility.
    Dustin E Voelzke (OP) - 1 year ago
    I appreciate the heads up. Still pretty new to all this. I will do just that!
  • Michael Smith / Smith's Metalworks - 11 months ago
    Yes, as James said i would be interested in if you could share the DXF, SVG or NC file so i can cut one of my own to build.
  • Bryan Rowen - 5 months ago
    I'd be interested too. Downloaded then read the comments and file extensions. Yep. Would definitely prefer a DXF file.
