47mm Castor and Drain Plug Wrench Tools
This is a remix of Mike Cloutier's simple wrench to adjust the casters on your CrossFire CNC Table. I redesigned the opposite end to include a 14mm box end to remove and install the water table drain plug.
Remix Of
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit William Cross for the original creation.
168
Castor Wrench CrossFire Drain Plug Wrench
  • 47mm Caster-Drain Plug Wrench.dxf
