6.7L Cummins Engine Lift Bracket Automotive
Needed a lift bracket for my engine. Drew this up and it worked great. Cut it out of 1/4 plate, I personally wouldn't go any thinner on the material. Use 4 x 8mm bolts 25mm long, 1.25mm thread pitch. Try to use a Gr 8.8 or higher bolt.
Creative Commons - Attribution - Share Alike
You may remix, tweak, and build upon this work even for commercial purposes, as long as you credit Myles Dahlin and license your new creations under the identical terms.
3 months ago
60
Cummins 6.7L diesel Engine
  • 6.7L Cummins Lift Bracket.dxf
