Air Compressor Aftercooler Bracket Tools
Designed for Derale 15300 with 12" inch Slim Fan (B014KK7Q84). You will need to bend this either by hand or with a press brakes, then to install the fan, drill holes and use rivnuts or bolts/washers. The bracket can be mounted directly, or use a corner brace such as Everbilt 15444.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Kyle Bottorff for the original creation.
61
  • flat pattern - aftercooler bracket.dxf
