AXA lathe tool holder wall mount Tools
This was designed to hold my AXA size quick change tool holders on a wall to get them out of drawers and keep them out of the chip tray. The size can be modified to fit larger size BXA & CXA tools if needed. Each bracket holds 5 tools to keep it optimized for smaller scrap usage and to keep them semi-modular. I made this out of 16g and it holds up well. The tabs are bent out 45 degrees after cutting and then the tab edges are rounded over with a die grinder. The Sheetmetal doesn't mark up the hardened tool holders but if you are worried about that you can always cut it out of aluminum. I have them mounted onto wooden 2x4 standoffs to get them closer to the lathe from the wall to help minimize reaching across a running lathe. I left a little room for a logo or whatever at the top, I tend to put Sawyer-Built or S~B on everything I make anymore just because I can-when kerf width doesn't give me fits :)
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Jon Sawyer for the original creation.
139
AXA Quick change Lathe tool holder AXA wall mount
  • AXA Lathe tool holder mount.dxf
  • Luke - 2 years ago
    excellent idea. i will be doing this soon. thanks
  • Anthony Garcia - 7 months ago
    great idea going to hang it up in the shop
