Bartenders Key Tools
Flat Openers or Bar Keys are simple to use openers. i have modified this one to allow for opening in either the forward down position or the common upwards motion. it also has a slot on the rear to hook around your belt loop. length is just under 7 inches 14ga thick material is what i have found to work best.
Remix Of
Bottle Opener Blank by Kevin Erickson
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Leonard Shapiro for the original creation.
6 years ago
743
bottle opener bar key speed opener flat opener bar bartenders key
  • Bartenders key.dxf
  • Robert Phillips - 6 years ago
    I like that you added a picture with dimensions.
    Leonard Shapiro (OP) - 6 years ago
    thanks, i wish everyone did
  • Donny Merrill - 5 years ago
    Thanks for the great info, I feel like you’ve given some great detail that most leave out. I see you said 14 gauge. Is that mild steel? Do you heat treat it?
