Bear with Inset Mountains Art
This was designed to be cut at least 22" (56cm) wide for the details. A good test for your consumables with 266 pierces. This was originally shared on PlasmaSpider a few years ago, I modified it to make it easier to cut.
3 months ago
165
Bear mountain tees wall art mountains
  • Bear with Inset Mountains.tap
  • Bear with Inset Mountains.dxf
  • Bear with Inset Mountains.svg
  • James Mersereau (OP) - 2 months ago
    If you want the dxf or svg files for this design they are included here. Simply click DOWNLOAD PROJECT FILES and choose AS-IS for the CUT READY file. You will then get a zipped file that contains all the files you see listed above under FILES.
