Brake & Throttle pedals for sim racing cockpit Tabs & Brackets
Making new pedals for the sim rig. I am not a pro at this by any means, but thought someone else might be in the same spot I am and could use these. This file will be just the pedals and arms. Will upload the mounting brackets and some final photos if anyone is interested as the project comes together. Not sure how this is going to work to be honest. This is a DXF file that was created on Fusion 360. If this does not work please let me know and I will try to correct it. I am going to list it as a basic project only because I had no issues creating or cutting it. ????????????????? I have had good luck with DXF files from this site, so I am assuming it will go well. The brake side will use a 100kg load cell and the throttle will use a hall effect switch when finished.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Jim Clark for the original creation.
96
Racing sim rig pedals
  • Sim pedals.dxf
  • lonnie burnsworth - 2 years ago
    some one please make this in to g code please!
    Nelson Montero - 2 years ago
    Ideally, you would make the g code yourself due to varying cut speeds, torch heights, etc. from one table to another.
    Jim Clark (OP) - 1 year ago
    Are you not able to open this file in your software? If this image is not working please let me know and I will take it down. Sorry that I did not see this earlier, I am on a very limited schedule and can not get back here all that often. I can share the G-code that I used but based on everything that I have read it might not work all that well for you. Every machine seems to be different from what I have gathered. I am still in the learning stages with this machine myself.
