Bus Ramps Wide Track Home & Garden
This is an updated version of the Bus Ramps I posted. When we started the production phase we decided that they were not wide enough. These are 11 inches wide. There are two .nc files for one ramp. You will need to do each of the two files twice to have a pair. I also included the .dxf so that anyone with an XR could cut a whole set in one sheet. We are using 1/8" tread plate for the production and I will add pictures to the comments when we get them welded up and in use.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Jason Ward for the original creation.
39
  • Bus Ramps Wide Track.dxf
  • Bus Ramps 1.nc
  • Bus Ramp 2.nc
  • Jason Ward (OP) - 2 years ago
    I have this set welded up I will post pictures on the forum.
