Compass Rose with Map Cut File Signs
There was a request for the .NC file for my compass rose. Since I can't add it to the original posting, I listed it as a remix. It is the exact same shape as the original.
Remix Of
Bret by Bret
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Bret for the original creation.
294
  • Compass Rose with Map.nc
  • mark dailey - 1 year ago
    Bret: Downloaded your file and just finished cutting. Worked Great! I slowed the feed down in FireControl but no other tweaks needed. Is it as difficult as it appears to create an .nc file from a .dxf file?
    Bret (OP) - 1 year ago
    I use Fusion 360 for both CAD and CAM (creating .nc file). It's not difficult once you know the sequence of steps. Basically, if you know how to setup your machine for the metal you'll be cutting, the software does the rest. FYI, a lot of people say SheetCAM is easier to use for creating the .nc files. I never bought it. F360 is free!
    Thanks for the info. I have the free version of Sheet Cam but i will download Fusion 360 and see if I can figure it out.
  • Jesse Burnsworth - 1 year ago
    yes thanks
  • Jeffrey Lay - 1 year ago
    i get a g code error when loading into firecontrol.
    Did you get this figured out? I have cut 5 or 6 of these in Firecontrol and got no errors. You can get the dxf file here and generate your own code if necessary. https://www.langmuirsystems.com/fireshare/bret
  • robert figueroa - 1 year ago
    thanks for the art
  • Merritt McCray - 8 months ago
    great job with the program, it came out awesome
