Contraption - Toilet Paper Holder Tabs & Brackets
Fun parts to make a fun toilet paper holder. Will have to assemble and provide other parts/ welding/ screws/ spacer. Pic shows idea behind the parts.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Mike Caffey for the original creation.
179
  • Contraption1.nc
  • Ed Elser - 4 years ago
    What does this do? please explain further
    Mike Caffey (OP) - 4 years ago
    Fun TP holder... Rotate handle up to vertical position.. shaft slides to the right... change out TP roll and rotate handle back to horizontal position.
  • Gerald Wiltshire - 4 years ago
    It appears once assembled you pull the lever to slide the roll holder over to change a roll.
    exactly.. It needs additional hardware to put together. I have also added bearings to the gears so is more smooth but works without them. I also put an extension behind handle to bring it out from base a little more... but just preference.
