designed these brackets to mount on the legs of a crossfire or crossfire pro so you can add a lower tray or storage without having to drill holes or do any cutting or welding, I cut them from 14 gauge hot rolled steel. each leg uses one of each of the attached files. the inner bracket has a relief cut and can easily be bent in a bench vice or brake. please note that the inner bracket differs from the photo as I have made it longer to clear the bolts, you will also need (16) 2.5" .250" bolts, (16) .250" nuts and (16) .250" lock washers. I have omitted my company logo so you can modify them with yours or leave them blank. cut at 33 amps 110 IPM with a razorweld 45 I saw minimal dross. Bolt holes are oversized to .180" so the bolts will fit freely. enjoy!
207
crossfire crossfirepro legs bracket shelf
