Crossfire Plate Quick-aligners Tools
These will help you quickly align sheets/drops with either axis on your table. The Y-axis tool leaves 1/8 - 3/16" before the carriage hits the mounting bolt. The X-axis tool can be used anywhere on the table really. There's obviously a window of accuracy with them, and you'll have to make sure your torch stays on the sheet during setup/cutting. They're more so for just squaring material to the axis'.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Nick Koupiaris for the original creation.
6 years ago
449
alignment
  • Crossfire X axis alignment tool.dxf
  • Crossfire Y axis alignment tool.dxf
  • Donald Pelkowski - 5 years ago
  • Cameron Stauffer - 5 years ago
    in the forum you said you ordered alignment lasers can you show me where you found them and how you are going to set them up? thanks
    adam - 2 years ago
    That would be cool. Did you ever find anything?
