Crossfire Pro Bottom Shelf Bracket Tabs & Brackets
One of the first brackets I designed as a learning project in Fusion360. The goal was to make a support for 2" tubing to support a bottom shelf. I didn't want to weld into the stock legs - this only requires 2 holes per leg. I used the sheet metal capabilities in F360 to make the flanges. This is also my first FileShare, so I thought I'd package it up to see how that works. Lots of ways to do this - this was what I came up with. If it helps you, hit like and leave a comment! Included tap (g-code) file with nesting for 4 parts ready to load and go. Make sure to remove the .txt extension! The tap file is based on a piece of 1/8" (.125 or 11ga) sheet 10" high x 7" wide to make all 4 parts. The bend radius calcs assume 1/8" material. You could make it with thinner or thicker material, but you'd need to adjust or not cut the bend lines to correct for the material thickness.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit James5 for the original creation.
931
Crossfire Pro Bottom Shelf CAD Fusion 360
  • CF Pro Shelf Bracket V3.dxf
  • CF Pro Shelf Bracket V3 - Sheetcam x 4 Tight.tap.txt
  • Tim Bledsoe - 5 years ago
    That looks great when I get my Pro setup I will be using it and let you know how it worked for me. Great Job
  • Keiwat - 5 years ago
    Thanks for the download I'll give it a try, just need to purchase material.
  • Curtis - 2 years ago
    What size, grade style bolt are you using to mount this?
  • Rene Loya - 2 years ago
    Thanks for the download. Cut perfectly and works great.
  • Steven Wimer - 4 months ago
    Thaks for the download. Just getting my Crossfire Pro set up. This will be a great help!
