This gauge will make it easy for you to accurately locate sheets and also to index sheets for larger parts than the footprint of the machine. The dxf is setup for 12 gauge material. The two edge pieces need to be welded together and cut with the Pro to create the edges that are perfectly straight to the axes of the machine. I will link some videos in the comments below that explain how its done. I used all 1/4-20 hardware to mount everything. 4 flathead , 16 panhead screws. I used 2 stick on rulers and claercoated over them then masked it off and bed lined the rest. I will also link videos that explain how I setup indexing from Inkscape,Sheetcam, and finally the machine cutting the index. The video show me cutting 48" in the y direction.
521
Advanced
joe juhl - 4 years ago
