CrossFire PRO Lead Screw Guards Tools
I wanted some lead screw guards that looked great and were inexpensive and effective. I cut these from 18Ga. sheet and because of the 4 point design and rib down the length of them they are plenty sturdy. For less than $15 in material, I'm sure they're worth it. This is the third time I have tried uploading so that's all I'm going to write this time.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Michael for the original creation.
511
Lead Screw Guards PRO
  • Lead Screw Guard.dxf
  • Curtis Burns - 3 years ago
    Would this fit the crossfire originals?
  • john messar - 3 years ago
    thank you for the file
  • Henry Kloepper - 3 years ago
    Worked great for my Crossfire Pro, however I did increase the length of the tabs to make bending easier, then welded the seam. Painted them black with high temp BBQ paint afterwards. Nice to be able to lean things up against the sides of the table without having to worry about the leadscrews.
