Included are dxfs for the plasma cut parts for the rolling base in the pics. I used HF 5inch casters, so the caster plate is designed around them. I turned down the 3/4 threaded rod to .6 inches x .75 inches long. I drilled and taped the end with for the 1/4" cap head screw. Hockey puck I countersunk the bottom of the puck with a 1-1/4" Forstner bit and drilled through the remainder with a 5/8 bit. Components List: (4) Base plate (4) 3-1/4” L3x3x3/16 angle (4)Caster mount plate (8)Gusset plates (4) 9” 3/4” T rod (12) 3/4” hex nut (4) 1/4 spring pins (4) hockey pucks (4) 3/4 flat washer (4) 1/4x1-1/4 fender washer (4) 1/4-20 x1/2” cap head screws Frame Tubing… I used 14ga 3x2 and 2x2 tube because I have a bunch of rejected remnant from a local treadmill manufacturer… use whatever.
52
Rolling base crossfire pro leveling casters
