Crossfire Pro X-Axis Motor Cable Support Tools
Simple 3D print that connects to the left Y axis lead screw mount, and supports the X axis motor cable up and off the lead screw. Change file type from DXF to STL to print!
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Graham for the original creation.
143
3D Print
  • Crossfire Pro X Axis Motor Cable Support.dxf
  • Timothy W Wood - 3 years ago
    what size bolt did you change to fit the bracket in place?
  • James Mersereau - 3 years ago
    Thanks, the stl printed great. I appreciate you sharing this.
