Crossfire XR laser alignment bracket Tabs & Brackets
I just got my Langmuir Crossfire XR setup and started to use it when I decided a laser alignment tool would speed me up when setting up my cuts. I looked around, but only found prints for the Crossfire Pro. After some thought here is what I came up with. For power I cut up an old USB cable and wired it to a switch I had laying around. I ran some 2 conductor wire up the track with the factory wires and connected it to the lasers with wago style connectors. I bought the lasers from Aliexpress. Originally I planed on using a set screw to hold the lasers in place, but ultimately decided to use a little hot glue instead. The actual STL can be downloaded from https://www.thingiverse.com/thing:5866505
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Brit Adams for the original creation.
52
laser alignment xr laser bracket
  • Dan A. Mefford - 2 years ago
    Hi Brit: I am new to this whole cnc machine. I am a maker/builder for many years. This looks like a great idea, however it would need, if I am reading it right, to have a part printed. My question is: Does the laser alignment happen automatically in the printed part? Thanks... Dan
  • spiderdesignandfabrication@gmail.com - 1 year ago
    What are you using for power supply? I tried a 3v-5v power cube with no luck.
