CrossFire XR Pointed Slats and Bottom Slats Tabs & Brackets
These are pointed slats for the CrossFire XR. I have posted two different files one for the horizontal slats and one for the vertical.
You may remix, tweak, and build upon this work non-commercially, as long as you credit landon and license your creations under the identical terms.
10 months ago
180
XR plasma Cutter slats table
  • plasma cutter slat 2.tap
  • plasma cutter Slat 1.tap
  • Jason Short - 9 months ago
    Can I get the dxf for the bottom slats. That would be great.
    landon (OP) - 9 months ago
    Hey Jason, I posted a remix of this Project in DXF form.
  • thomas kelly - 4 months ago
    Just cut these. Came out great using my own cut settings you should change the IPM to around 100 at 45amps. Cut beautiful with zero dross on that back. Now these stick about 1/2” taller then the water on my original lower slat holder. If I cut your lower slats will it lower them or should I draw my own.
