Fab Corner Tools
A poor man's riser block and fab square hybrid. Made with 1/8" plate. The gussets could be left off to be an inside corner square too. The holes are a little small on purpose to be reamed out with a 16mm drill bit. The pieces are all a little different and only go together one way.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Chuck Jolly for the original creation.
275
  • FAB CORNER 31x10.125.dxf
  • Henry Kloepper - 4 years ago
    I cut and put together one of these. Went together easily and with a little care came out plenty square. Worth cutting from thicker material if you want a more durable square, but would require reworking the file to accommodate the thicker materials tabbing together. Good share!
  • Todd Heath - 3 years ago
    That is a great idea
