Floor plate/ spacer plate Tabs & Brackets
This plate is 4" X 4" with 3/8" hole spaced 1/2" from the edges. Could be used for caster spacers or for floor plates to anchor to the ground. This is set up to cut on 1/4" steel
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Shayne McCoy for the original creation.
7 months ago
122
floor plate caster spacer square plate
  • Spacer plates 4X4 with .375 holes at .5X.5.nc
