Ford Mustang Coyote 5.0 PCM Mounting Brackets Automotive
Here is a DXF file of a couple different brackets ive used to mount the factory pcm for a GEN 1 Coyote PCM aka Copperhead PCM. The main dimensions needed are the 2 slots and the center cutout for the pcm, and everything outside of that you can change to whatever you want. Not going to include the cut ready file since my method for how i setup my cut files isn't like most others. I also have absolutely no desire to spoon feed lazy people.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit AEF FAB for the original creation.
55
Ford Mustang Coyote PCM Swap 5.0 ECU Copperhead Mount Bracket
  • AEF GEN1 Coyote Copperhead PCM Brackets.dxf
