Funkey BO-105 Scale RC Helicopter Tail Servo Mount Tabs & Brackets
Here's an indestructible Tail Servo Mount for the Funkey Scale BO-105 RC Helicopter. Cut from 16g Galvanized Steel, it also solves some of the issue of needing a bit of tail-weight to compensate for extended flight LiPo battery packs in the nose of the fuselage. The original under-designed ply-wood component easily failed in gusty winds, bringing this beautiful bird to the ground. The mounting holes are way too small for plasma cutting so those were left for hand drilling operations.
6
RC RC Helicopters BO105
  • BO 105 Tail Servo Mount.dxf
