gantry x axis support Tools
I got frustrated adjusting the torch height after short periods of cutting. This setup aligns the bearing with the torch centerline so will work with the table extension without losing any travel. Parts are less than 10.00. Picked up metal roller bearing at harbor freight for 2.00. unit slides into 2" sq tube and attaches with the bearing block screws. Fought with the screws and would through drill the tubing for allen wrench access. Locks in tight. Used for 2 hrs and no sagging gantry. Requires some welding.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit David Frey for the original creation.
6 years ago
205
  • a axis guide.dxf
  • Steve Huebert - 4 years ago
    When I download and open in Fusion 360 the parts are very small
  • Mickey Lawson - 4 years ago
    What is the piece that the two arms are welded to?
