Geodesic Fire Pit with base Home & Garden
This project includes several options for patterns to use, you can mix and match or repeat the same image. You need: 1 Solid Pentagon 5 Solid Hexagons 5 Patterned Pentagons 5 Patterned Hexagons 5 Half Pentagons 5 Base Pieces You can keep adding pieces to continue the shape.
357
Fire pit geodesic Fire
  • GeodesicFireBall.dxf
  • Sebastián - 4 years ago
    muy chulo .Gracias
  • Cyrus - 4 years ago
    how much metal does it take to make one?
    also could you please upload the dxf in the picture that has all the pieces conjoined with relief cuts
