HF Vulcan welding cart (63179) Tig rod rack upgrade Tools
This rack is a direct bolt on to the Harbor Freight 500lb cart. Uses 1.5" PVC tubing. I cut it using 16Ga. Don't glue the caps! The tubes drop through the top then insert the caps.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Frank L for the original creation.
219
HF Vulcan Welding cart Harbor freight tig rod rack
  • HF Tig rod rack lower 16g.nc
  • HF Tig rack upper 16ga.nc
