Hydraulic press base plates Tools
Cut these from your chosen thickness. I cut these from 1/2" and stack them for adequate strength. You can also weld them together when stacked to make thicker plates.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit mike koloff for the original creation.
179
hydraulic press base plates tools shop
  • square multi.dxf
  • v rectangle.dxf
  • Anthony Garcia - 7 months ago
    thanx for sharing
