Jeep LJ Rubicon Wrangler Locker Pump Relocation Bracket Automotive
This relocates the OEM Jeep LJ Rubicon locker pump from the skid plate to the drivers side rear fenderwell, in the same cavity as the fuel filler neck. You'll need to use a right angle drill to drill into the support bracket, which is the most awkward part. Otherwise, there's plenty of room in here on an LJ. It may even be possible to get this into a TJ, I haven't tried, and it would require a bit more work I'm guessing.
You may remix, tweak, and build upon this work non-commercially, as long as you credit DMopar and license your creations under the identical terms.
2 months ago
4
jeep wrangler lj rubicon
  • LJ rubicon locker pump relocate.DXF
