Jeep wrangler JK rear light covers and foot pegs Automotive
I used 16ga steel for light covers and top layer of the sandals. I used 1/8" steel for foot peg and lower sandal. I used center compensation for cut path. I would recommend cutting out of thinner cheap steel the first time and making sure it fits prior to using 1/8" steel due to cost. You'll need to weld lower sandal to the foot peg. I'm posting this so you don't have to try figuring a working design out yourself. You can put any design on this within minutes. You can make some money if you come up with cool design. Message me in the forum if you have issues or questions.
180
  • Jeep JK rear lights and footpegs.dxf
  • Ethan Perry - 10 months ago
    I am just wondering what scale to use , when i use metric the frames are only .5in and when i use inchs they are 14.7in. Thanks!
