This uses existing holes and nuts in the tub. It attaches with two bolts, one from the back seat bracket, and one from the car seat anchor point. You'll need to get a longer bolt for the rearmost car seat anchor bolt. I don't recall the size (8mmx50mm? it's a common metric size). The tie down braces are tabbed and slotted into the "L" shaped piece for welding from the bottom side. I used 1/4 steel, and the slots are for 1/4" plate.
3 months ago
12
jeep LJ cargo tie down ratchet strap tj wrangler
