Komatsu pc35 mr2 hydraulic thumb Tools
Had a pin and bushings milled for this project that was the most expensive part at 400$. steel used for thumb was 1/2 in. razor weld cut it no problem, though there was about a 1/16 in deflection in the cut really maxed machine out. yes it looks like it is sticking out a lot but it is not retracted all the way as the lines were not hooked up when I took this picture.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit mark for the original creation.
196
Advanced
Hydraulic Thumb
  • thumb1.svg
  • cyinder mount 1.svg
  • cyinder mount 2.svg
  • Langmuir Systems - 4 years ago
    This is awesome!
  • mark (OP) - 4 years ago
    An additional note, the mounts for cylinder are double so 1" and then a few spacers cut from 14g.
  • Brandon Berkosky - 4 years ago
    hey, thinking of using your design for my backhoe, what is the length dimension? I need 36" from bucket pin to bucket teeth. Thanks.
    Shouldnt you be able to see the dimensions when you open files? I cut a few out of 16g first to make sure it fit before i cut the 1/2in also
    yes, worked perfect, thanks!!
