Langmuir Gantry Riser Tools
These Plates are 1" taller to raise the gantry on the Crossfire for doing notching or cutting on 2" square tubing. Cut 4 of these plates out of 3/16" plate. I take a drill bit to straighten up the holes once cut. 5/16" on the 2 small holes and 3/8" on the larger holes.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Blake Terry for the original creation.
414
Table modification
  • Langmuir Riser Plates.dxf
  • Joseph Smith - 4 years ago
    I was just looking at mine the other day and wanting to pass the material under the gantry as we were laying out then cutting the dash for a CJ7. But there was no room and I couldn't see any reason to not raise them a little so I could. Thanks for making these.
  • Justin - 4 years ago
    I had exactly the same problem as Joseph Smith, thanks so much for making this plug and play.
  • RyanKim3612@gmail.com - 3 years ago
    So very cool. Thank you.
  • Luke - 2 years ago
    this worked exactly as i had hoped for. very very simple and seems to provide all sorts of new clearance to bring material under the y axis
  • Jason Thayer - 2 years ago
    This is very awesome, only question how do i turn this into a file FireControl can read? any advice would be greatly appreciated. 989-627-7351 sorry for the newbie question
  • John Edmundson - 2 years ago
    Is this the highest the gantry can be moved up and have the crossfire still operate?
