Laptop stand for crossfire PRO Tools
This is a remix of the original laptop stand by Wyatt Lassiter, made for the Crossfire PRO, so it bolts to the corner of the table instead of a leg since the PRO's gussets make the leg not usable. I added gussets and widened the piece attached to the bottom of the laptop holder part to stiffen it up since I was going to use thinner material, if you are using the 1/8" that was suggested, it may not be necessary. I also modified the main piece and added brackets to hold a three piece pipe hinge instead of the original purchased hinge because that's what I had. They're sized for 1.5" OD pipe but feel free to adjust for what you have.
Remix Of
Laptop Stand for Crossfire by Wyatt Lassiter
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Michael for the original creation.
1240
  • Laptop Stand for PRO.dxf
  • David - 4 years ago
    THANK YOU! This as my first "real" project. 1/8" steel, 50ipm 45 am and all as perfect with cuts. I may change the pivot arm but not because of any errors in your design.Again..thank you
  • Todd Kelch - 4 years ago
    thanks David!
  • Portagee Customs - 4 years ago
    I cut this out of 16 gauge steel, kinda light and would not recommend. but it's all I had. That being said its super strong despite the thinner steel. Excellent file.
  • Mark Dunham - 3 years ago
    Thanks
  • Leben Mjos - 3 years ago
    thanks
  • joseph wolf - 2 years ago
    Thanks
  • taylor crahan - 1 year ago
    cool, thanks
  • Douglas Fox - 1 year ago
    If I can get it to download ..... It will be great
  • kevin jackson - 1 year ago
    Cutting now. I'll post pics later. Thanks!
  • Ryan Powell - 4 months ago
    This worked out great! I just used the same hinge recommended with the original CrossFire laptop stand found on fire share. I didn’t grab any photos but do have an instagram video that I shared: https://www.instagram.com/share/BBMh7SMnVg
  • scott - 3 months ago
    Thanks for the download
