Laptop stand remix Tools
Added simple bracket to attach to table corner instead of bolted leg bracket . Trying to figure out how to upload dxf or tap file
Remix Of
Laptop Stand for Crossfire by Wyatt Lassiter
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Shawn Smith for the original creation.
468
  • Shawn Smith (OP) - 5 years ago
    I know, awful welding but I'm learning!
    Rustin Sparks - 5 years ago
    Go man, go! Nothing will make you a better welder than practice! (also, slow down on your advance and back into it to wait for the puddle) You'll be ruining perfectly good steel with the best of us in no time!
  • Millar Farewell - 5 years ago
    Hello Shawn, nice remix of the laptop stand. You can drag the dxf file into the message window and it will get uploaded. the tap file may not be useful unless they have the same plasma cutter as you.
    need to use custom 1:10 ratio in Sheetcam when opening to get correct size
