LS ENGINE LIFT PLATE Automotive
Lift plate to remove 4.8 5.3 6.0cheevy ls engines from autos. RTC
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Michael Reaves for the original creation.
576
  • Ls lift plate.gcode
  • Greg - 2 years ago
    HI Michael Thank you for the files! What thickness material should be used?
    Michael Reaves (OP) - 11 months ago
    i used 1/8
  • Ryan Garofalo - 2 years ago
    Hey Michael, Any chance you can post the DXF File instead of the G-Code files? I have a different Crossfire and I need to post process it differently. Thank you in advance! Ryan
    CHAD VIGAR - 1 year ago
    Hey Ryan, did you ever get the DXF? if so would you be able to share?
    Chris - 1 year ago
    Anyone ever get the dxf for this?
  • Matthew Malo - 5 months ago
    i used 1/8 " works great! thanks so much for the file!!
  • Mario Madrigal - 5 months ago
    Does anyone has the DXF file?
