LS engine mount adapter plates Automotive
These are the correct hole spacing measurements for an LS engine mount adapter. Three top right holes will need to be countersunk depending on bolts used to install motor mount and to attach to engine block.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Russell Harris for the original creation.
699
  • LS engine mount adapter.dxf
  • Russell Harris (OP) - 5 years ago
    I forgot to add, cut out of 1/4" mild steel.
  • Mario Madrigal - 7 months ago
    Thanks Russel
