Magic Welding Square Tools
I built a Magic Square for certain welding projects where getting 90 deg can be difficult and accuracy is important. Seen this on (Fireball Tools Youtube) I used 2 inch by 3/8 inch flat bar for the edges as I had that in stock and also a 3/8 bolt 1 1/2 inch long with a lock nut to connect the two peace's, I welded the two pieces offset so that the edges will align ( add your washer first) I was able to find a tightening lever off a old computer screen mount but sure you can get that online or even use a bolt with a wing nut or weld a lever on a bolt and make the hole from 1/4" to 3/16" and tap and thread it ( was an after thought). Have fun
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Jordan Beukema for the original creation.
835
  • Magic Square.dxf
  • Sebastián - 5 years ago
    gran proyecto .Gracias x compartir.
  • Jim Maltby - 5 years ago
    Cool, Thanks !
  • william fridley - 3 years ago
    i'm going to go one step further with these and finish off the square edges in the milling machine and surface grinder. may even mill a v groove to help hold round tube .
  • IronmanMetal - 3 years ago
    Thanks, this is great. What plasma machine did you use?
  • Timothy Suchonic - 2 years ago
    thanks
  • jerry - 5 months ago
    looks awesome
