Michigan deer tag mount Outdoor
This is a 20"x16" wall mount for a deer head. The wall mount represents a Michigan hunting license. I added one of my swivel mounts so you can face the head right or left. It made for bigger rack so if you want to add a smaller spike horn you may want to shorten the distance from wall to swivel. On this mount I used the holes in the swivel bracket to weld on the license. just offset them a little so you can tack on front and back and grind smooth. The horns on it are from last year not meant for this wall mount but showing how it'll display when finished. Good luck and happy hunting!
288
  • Michigan deer tag mount.dxf
  • Erick Schultz - 2 years ago
    What font did you use to make this? Asking because I'd like to change the year.
  • John Sabarese - 2 years ago
    Not sure what font was used but why don't you just use the smaller numbers provided and move enlarge them to suit what year you want
  • Don P. (OP) - 2 years ago
    It's called Amusette High Stencil
  • MATT DUGAS - 2 years ago
    NICE
    How did you put the rusy finish on it ? Vinegar?
    white distilled vinegar, hydrogen peroxide, and salt
  • Dustin - 3 months ago
    Cant get the file to open in auto cad. any help would be appreciated
