Motor Guard M60 Mount Tabs & Brackets
Motor Guard M60 air cleaner mounting bracket. This is another take on a mount for the Motor Guard M60 mount with 1/2" NPT inlet/outlet. This has tabs to capture the 1/2 pipe securely. It is designed to work with McMaster-Carr 4" exhaust bracket part # 3042T23 or it can be mounted directly to a wall. Holes/slots are 3/8" and oversized to 0.3970. Bends assume this is cut from 0.125 (1/8") material. Also includes an optional locking plate that can be secured with #10 bolts to capture the 1/2" pipe. When cutting, make sure to cut the bend lines with no offset (or skip them if you want). Filter not included :) Happy Cutting! Leave a comment below if this helped you out! Enjoy!
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit James5 for the original creation.
564
Motor Guard Motorguard M60 Motorgard Filter bracket
  • M60-flatpattern.dxf
  • M60-lockplate-flatpattern.dxf
  • scott - 3 years ago
    thanks so much for this file. looks great
