Neil Bernard Tools
This is a DXF for a machine torch mount made out of 3/16" steel, you will need 1/4" bolts and a welder to assemble it. I had to take a flapper disk to the inside of the clamp to get it to fit the machine torch perfectly.
You may remix, tweak, and build upon this work non-commercially, and although your new works must also acknowledge Neil Bernard and be non-commercial, you don’t have to license your derivative works on the same terms.
108
  • machine torch clamp.dxf
  • Neil Bernard (OP) - 2 years ago
    Just figured I should mention it's for the machine torch that comes with the everlast 62i which is 34.5mm diameter.
    Michel Blouin - 1 year ago
    Is there some place for fine tuning...mine is a Hypertherm 45 with 35 mm Thanks
  • Bill Dank - 1 year ago
    Thanks,just made one and works great. God bless
