MAHALO TO ROCK MOUNTAIN FAB FOR THE IDEA AND OG DESIGN. MADE FROM 12G HOT ROLL. THIS IS A RIVET TOGETHER VERSION. 3/16 DIA. DESINED TO MOUNT ON THE LEFT OF THE MACHINE. ONLY REAL INTERFERANCE I HAD WAS THE BOOM POLE. JUST HAD TO DO AN S BEND AND WORKS BEAUTIFUL. **IF USING A HAND TORCH THE BELOW STATEMANT WOULD NOT EFFECT YOU ON PLACEMANT OF THE TOP PCS** TOP PLATES HAVE HOLES ALREADY. WILL NEED TO DRILL THE RISER WHEN YOU HAVE ACHEVED CORRECT POSION, WHERE THE MACHINE TORCH DOESNT COME IN CONTACT WITH THE SHELF. THE TOP MOUNTS A BIT OFFSET TO CENTER OF RISERS,SO IT DOES NOT INTERFERE WITH THE MACHINE TORCH.
52
PLASMA SHELF
